Voraussetzung zum kompilieren schaffen
apt-get install libevent-dev libssl-dev libglew-dev xorg-dev libglu1-mesa-devQuelldateien via Git holen
git clone https://bitbucket.org/defnull/pixelnuke.gitIn das Verzeichnis pixelnuke wechseln
cd pixelnukeCode: Select all
git submodule init
git submodule update zum kompilieren make ausführen
makeFür den Client
Voraussetzung
apt-get install libjpeg-dev libfreetype6 libfreetype6-dev zlib1g-dev python3 python3-pip python3-dev python3-imaging python3-pilClient Beispiel Quellcode für Python3
__author__ = 'progamler'
from PIL import Image, ImageFilter
import subprocess
import socket
from time import sleep
from random import shuffle,randrange
TCP_IP = '192.168.123.234'
TCP_PORT = 1234
BUFFER_SIZE = 1024
MESSAGE = "Hello, World!"
conns = 1
start_ip = 50
loc_w = 300
loc_h = 300
max_w = 800
max_h = 576
im = Image.open("/home/BENUTZER/pixelflut/bild.jpg")
x, y = im.size
max_w = max_w - x
max_h = max_h - y
print(im.size)
rgb = im.convert('RGB')
list = []
print(x)
print(y)
for i in range(0,3,1):
for x_i in range(1, x):
for y_i in range(1, y):
r, g, b = rgb.getpixel((x_i,y_i))
r = str(hex(r))
g = str(hex(g))
b = str(hex(b))
r = r[2:]
g = g[2:]
b = b[2:]
if len(r) == 1:
r = "0" + r
if len(g) == 1:
g = "0" + g
if len(b) == 1:
b = "0" + b
list.append([x_i,y_i,r,g,b])
shuffle(list)
# generate ip addresses
#for ip in range(start_ip,start_ip+conns+1,1):
# subprocess.Popen(["/usr/bin/ip addr add 10.20.30." + str(ip) +"/22 dev enp0s25"], shell=True)
sleep(1)
s = []
ip = start_ip
for i in range(0,conns,1):
print("a")
s.append(socket.socket(socket.AF_INET, socket.SOCK_STREAM))
print("b")
# s[i].bind(('10.20.30.' + str(ip) ,0))
print("c")
s[i].connect((TCP_IP, TCP_PORT))
print("d")
ip = ip+1
print("con " + str(i))
while True:
loc_h = randrange(0,max_h,1)
loc_w = randrange(0,max_w,1)
print("y=" + str(loc_h) + " x=" + str(loc_w))
i = 0
for bla in range(0, len(list), conns):
bar = 0
for bar in range(0,conns,1):
try:
msg = "PX " + str(int(list[bla+bar][0]+loc_w)) + " " + str(list[bla+bar][1]+loc_h) + " " + list[bla+bar][2] + list[bla+bar][3] + list[bla+bar][4] + "\n"
s[bar].send(bytes(msg, 'UTF-8'))
except:
pass
bar = bar + 1
i = i+1
if i == 99:
sleep(0.0001)
i = 0
print("wait")
s[i].close()
for ip in range(start_ip,start_ip+conns,1):
subprocess.call(["ip addr del 10.20.30." + str(ip) +"/22 dev enp0s25"], shell=True)
