Mustek 1200 CU Plus unter Ubuntu
Fassung vom 24.09.2021
Quelle: https://code.fastix.org/Projekte/Linux% ... installer/
wget 'https://4noobs.de/download/file.php?id=245' -O install.sh;
chmod +x install.sh;
sudo ./install.sh
#!/usr/bin/sudo /bin/bash
startDir=$(pwd);
[b]Scanner Firmware[/b]
[attachment=1]sbfw.tar.gz[/attachment]
if [ -d '/usr/share/sane/' ]; then
        if [ ! -d '/usr/share/sane/gt68xx' ]; then
                mkdir '/usr/share/sane/gt68xx';
                chmod 755 '/usr/share/sane/gt68xx';
        fi
        cd '/usr/share/sane/gt68xx';
        echo 'Driver firmware download directory is:';
        pwd;
        echo 'Starting downlad...';
        wget 'https://4noobs.de/download/file.php?id=243' -O sbfw.tar.gz;
        tar xzf sbfw.tar.gz;
        rm sbfw.tar.gz;
        chmod 644 'sbfw.usb';
        cd '/etc/sane.d/';
        echo "Seting up /etc/sane.d/gt68xx.conf file";
        myDate=$(date '+%F_%H:%M:%S');
        sed -i.backup_${myDate}  -e 's/^#override "mustek-scanexpress-1200-ub-plus"/override "mustek-scanexpress-1200-ub-plus"/' 'gt68xx.conf';
        echo "Device should be ready for use!"
        echo '';
        sleep 3;
        cd $startDir;
else
        echo 'Sane is not installed. I try to install and restart:';
        echo '';
        apt update; apt install sane;
        $0;
fi
install.sh
Auto Installer
(1.1 KiB) Downloaded 9356 times
sbfw.tar.gz
Mustek Scanner Firmware
(4.76 KiB) Downloaded 9388 times
