Native Jitsi Meet Installation unter Debian Buster https://jitsi.org/downloads/ubuntu-debi ... tructions/
Jitsi Repository hinzufügen
wget -qO - https://download.jitsi.org/jitsi-key.gpg.key | sudo apt-key add -
sudo sh -c "echo 'deb https://download.jitsi.org stable/' > /etc/apt/sources.list.d/jitsi-stable.list";
sudo apt-get -y update;
sudo apt-get -y install jitsi-meet nginx certbot;Code: Select all
/usr/share/jitsi-meet/scripts/install-letsencrypt-cert.shDebugging unter Debian Buster!
Die URL jitsi.example.com gegen die eigene austauschen!
rm /etc/nginx/modules-enabled/60-jitsi-meet.conf
sed -i 's/4444/443/g' /etc/nginx/sites-available/jitsi.example.com.conf
sed -i 's/ssl_protocols TLSv1 TLSv1.1 TLSv1.2;/ssl_protocols TLSv1.2 TLSv1.3;/g' /etc/nginx/sites-available/jitsi.example.com.confCode: Select all
sed -i 's/--https_certificate =/https_certificate =/g' /etc/prosody/prosody.cfg.luaCode: Select all
systemctl restart nginx.service;
systemctl status nginx.service --no-pager;
systemctl restart prosody.service;
systemctl status prosody.service --no-pager;Jitsi Monitoring mit dem TIG Stack
InfluxDB Installation
https://docs.influxdata.com/influxdb/v1 ... tallation/
Grafana Installation
https://grafana.com/docs/grafana/latest ... on/debian/
Telegraf auf dem Jitsi Meet Server installieren
https://docs.influxdata.com/telegraf/v1 ... tallation/
sed -i 's/JVB_OPTS="--apis=,"/JVB_OPTS="--apis=rest,"/g' /etc/jitsi/videobridge/config
sed -i 's/org.jitsi.videobridge.STATISTICS_TRANSPORT=muc/org.jitsi.videobridge.STATISTICS_TRANSPORT=muc,colibri/g' /etc/jitsi/videobridge/sip-communicator.propertiesCode: Select all
"__inputs": [
"name": "DS_INFLUXDB",
"label": "InfluxDB",
"description": "",
"type": "datasource",
"pluginId": "influxdb",
"pluginName": "InfluxDB"
"__requires": [
"type": "grafana",
"id": "grafana",
"name": "Grafana",
"version": "6.6.2"
"type": "panel",
"id": "graph",
"name": "Graph",
"version": ""
"id": "influxdb",
"name": "InfluxDB",
"version": "1.0.0"
"type": "panel",
"id": "stat",
"name": "Stat",
"version": ""
"annotations": {
"list": [
"builtIn": 1,
"datasource": "-- Grafana --",
"enable": true,
"hide": true,
"iconColor": "rgba(0, 211, 255, 1)",
"name": "Annotations & Alerts",
"type": "dashboard"
"description": "Gather performance metrics from Jitsi Meet Videoconferencing stack",
"editable": true,
"gnetId": 11969,
"graphTooltip": 0,
"id": null,
"iteration": 1584914212832,
"links": [],
"panels": [
"datasource": "${DS_INFLUXDB}",
"gridPos": {
"h": 4,
"w": 2,
"x": 0,
"y": 0
"id": 14,
"options": {
"colorMode": "value",
"fieldOptions": {
"calcs": [
"lastNotNull"
"defaults": {
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "red",
"value": 80
"unit": "percent"
"overrides": [],
"values": false
"graphMode": "area",
"justifyMode": "auto",
"orientation": "auto"
"pluginVersion": "6.6.2",
"targets": [
"groupBy": [
"params": [
"$interval"
"type": "time"
"measurement": "jitsi_stats",
"orderByTime": "ASC",
"policy": "default",
"refId": "A",
"resultFormat": "time_series",
"select": [
"params": [
"cpu_usage"
"type": "field"
"params": [],
"type": "mean"
"tags": [
"key": "host",
"operator": "=~",
"value": "/^$jitsi_host$/"
"timeFrom": null,
"timeShift": null,
"title": "CPU Usage",
"type": "stat"
"gridPos": {
"h": 4,
"w": 2,
"x": 2,
"y": 0
"id": 21,
"options": {
"fieldOptions": {
"calcs": [
"lastNotNull"
"defaults": {
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"overrides": [],
"values": false
"targets": [
"groupBy": [
"params": [
"$interval"
"type": "time"
"refId": "A",
"select": [
"params": [
"threads"
"type": "field"
"params": [],
"type": "mean"
"tags": [
"key": "host",
"operator": "=~",
"timeFrom": null,
"timeShift": null,
"title": "Threads",
"type": "stat"
"gridPos": {
"h": 4,
"w": 3,
"x": 4,
"y": 0
"id": 2,
"options": {
"fieldOptions": {
"calcs": [
"lastNotNull"
"defaults": {
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "red",
"value": 80
"overrides": [],
"values": false
"targets": [
"groupBy": [
"params": [
"$interval"
"type": "time"
"refId": "A",
"select": [
"params": [
"conferences"
"type": "field"
"params": [],
"type": "mean"
"tags": [
"key": "host",
"operator": "=~",
"timeFrom": null,
"timeShift": null,
"title": "Conferences running",
"type": "stat"
"gridPos": {
"h": 4,
"w": 3,
"x": 7,
"y": 0
"id": 5,
"options": {
"fieldOptions": {
"calcs": [
"lastNotNull"
"defaults": {
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "red",
"value": 80
"overrides": [],
"values": false
"targets": [
"groupBy": [
"params": [
"$interval"
"type": "time"
"refId": "A",
"select": [
"params": [
"largest_conference"
"type": "field"
"params": [],
"type": "mean"
"tags": [
"key": "host",
"operator": "=~",
"timeFrom": null,
"timeShift": null,
"title": "Largest Conference",
"type": "stat"
"gridPos": {
"h": 4,
"w": 3,
"x": 10,
"y": 0
"id": 17,
"options": {
"fieldOptions": {
"calcs": [
"lastNotNull"
"defaults": {
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "red",
"value": 80
"unit": "ms"
"overrides": [],
"values": false
"targets": [
"alias": "RTT",
"groupBy": [
"params": [
"$interval"
"type": "time"
"params": [
"none"
"type": "fill"
"refId": "A",
"select": [
"params": [
"rtt_aggregate"
"type": "field"
"params": [],
"type": "mean"
"tags": [
"key": "host",
"operator": "=~",
"timeFrom": null,
"timeShift": null,
"title": "RTT Aggregate",
"type": "stat"
"gridPos": {
"h": 4,
"w": 3,
"x": 13,
"y": 0
"id": 23,
"options": {
"fieldOptions": {
"calcs": [
"lastNotNull"
"defaults": {
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "red",
"value": 80
"unit": "ms"
"overrides": [],
"values": false
"targets": [
"alias": "Jitter",
"groupBy": [
"params": [
"$interval"
"type": "time"
"params": [
"none"
"type": "fill"
"refId": "A",
"select": [
"params": [
"jitter_aggregate"
"type": "field"
"params": [],
"type": "mean"
"tags": [
"key": "host",
"operator": "=~",
"timeFrom": null,
"timeShift": null,
"title": "Jitter Aggregate",
"type": "stat"
"gridPos": {
"h": 2,
"w": 2,
"x": 16,
"y": 0
"id": 20,
"options": {
"fieldOptions": {
"calcs": [
"lastNotNull"
"defaults": {
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "red",
"value": 80
"overrides": [],
"values": false
"targets": [
"groupBy": [
"params": [
"$interval"
"type": "time"
"params": [
"null"
"type": "fill"
"refId": "A",
"select": [
"params": [
"total_conferences_created"
"type": "field"
"params": [],
"type": "mean"
"tags": [
"key": "host",
"operator": "=~",
"timeFrom": null,
"timeShift": null,
"title": "Cf created",
"type": "stat"
"gridPos": {
"h": 2,
"w": 2,
"x": 18,
"y": 0
"id": 15,
"options": {
"fieldOptions": {
"calcs": [
"mean"
"defaults": {
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"unit": "decbytes"
"overrides": [],
"values": false
"graphMode": "none",
"targets": [
"alias": "bytes_rx",
"groupBy": [],
"refId": "A",
"select": [
"params": [
"total_bytes_received"
"type": "field"
"params": [],
"type": "last"
"tags": [
"key": "host",
"operator": "=~",
"timeFrom": null,
"timeShift": null,
"title": "Bytes RX",
"type": "stat"
"gridPos": {
"h": 2,
"w": 2,
"x": 20,
"y": 0
"id": 11,
"options": {
"fieldOptions": {
"calcs": [
"mean"
"defaults": {
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "red",
"value": 80
"overrides": [],
"values": false
"targets": [
"groupBy": [],
"refId": "A",
"select": [
"params": [
"audiochannels"
"type": "field"
"params": [],
"type": "last"
"tags": [
"key": "host",
"operator": "=~",
"timeFrom": null,
"timeShift": null,
"title": "Audiochan",
"type": "stat"
"gridPos": {
"h": 2,
"w": 2,
"x": 22,
"y": 0
"id": 3,
"options": {
"fieldOptions": {
"calcs": [
"mean"
"defaults": {
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "red",
"value": 80
"overrides": [],
"values": false
"targets": [
"groupBy": [],
"refId": "A",
"select": [
"params": [
"participants"
"type": "field"
"params": [],
"type": "last"
"tags": [
"key": "host",
"operator": "=~",
"timeFrom": null,
"timeShift": null,
"title": "Participants",
"type": "stat"
"gridPos": {
"h": 2,
"w": 2,
"x": 16,
"y": 2
"id": 4,
"options": {
"fieldOptions": {
"calcs": [
"mean"
"defaults": {
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "red",
"value": 80
"overrides": [],
"values": false
"targets": [
"groupBy": [],
"refId": "A",
"select": [
"params": [
"total_channels"
"type": "field"
"params": [],
"type": "last"
"tags": [
"key": "host",
"operator": "=~",
"timeFrom": null,
"timeShift": null,
"title": "Total Chan",
"type": "stat"
"gridPos": {
"h": 2,
"w": 2,
"x": 18,
"y": 2
"id": 16,
"options": {
"fieldOptions": {
"calcs": [
"mean"
"defaults": {
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"unit": "decbytes"
"overrides": [],
"values": false
"targets": [
"alias": "bytes_tx",
"groupBy": [],
"refId": "A",
"select": [
"params": [
"total_bytes_sent"
"type": "field"
"params": [],
"type": "last"
"tags": [
"key": "host",
"operator": "=~",
"timeFrom": null,
"timeShift": null,
"title": "Bytes TX",
"type": "stat"
"gridPos": {
"h": 2,
"w": 2,
"x": 20,
"y": 2
"id": 12,
"options": {
"fieldOptions": {
"calcs": [
"mean"
"defaults": {
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "red",
"value": 80
"overrides": [],
"values": false
"targets": [
"groupBy": [],
"refId": "A",
"select": [
"params": [
"videochannels"
"type": "field"
"params": [],
"type": "last"
"tags": [
"key": "host",
"operator": "=~",
"timeFrom": null,
"timeShift": null,
"title": "Videochan",
"type": "stat"
"gridPos": {
"h": 2,
"w": 2,
"x": 22,
"y": 2
"id": 13,
"options": {
"fieldOptions": {
"calcs": [
"mean"
"defaults": {
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "red",
"value": 80
"overrides": [],
"values": false
"targets": [
"groupBy": [],
"refId": "A",
"select": [
"params": [
"videostreams"
"type": "field"
"params": [],
"type": "last"
"tags": [
"key": "host",
"operator": "=~",
"timeFrom": null,
"timeShift": null,
"title": "Vid Streams",
"type": "stat"
"aliasColors": {},
"bars": false,
"dashLength": 10,
"dashes": false,
"fill": 1,
"fillGradient": 0,
"gridPos": {
"h": 7,
"w": 8,
"x": 0,
"y": 4
"hiddenSeries": false,
"id": 7,
"legend": {
"alignAsTable": true,
"avg": true,
"current": true,
"max": true,
"min": true,
"show": true,
"total": false,
"values": true
"lines": true,
"linewidth": 1,
"nullPointMode": "null",
"options": {
"dataLinks": []
"percentage": false,
"pointradius": 2,
"points": false,
"renderer": "flot",
"seriesOverrides": [
"alias": "bit_rate_download",
"transform": "negative-Y"
"spaceLength": 10,
"stack": false,
"steppedLine": false,
"targets": [
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"null"
"type": "fill"
"refId": "A",
"select": [
"params": [
"bit_rate_download"
"type": "field"
"params": [],
"type": "mean"
"tags": [
"key": "host",
"operator": "=~",
"alias": "bit_rate_upload",
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"null"
"type": "fill"
"refId": "B",
"select": [
"params": [
"bit_rate_upload"
"type": "field"
"params": [],
"type": "mean"
"tags": [
"key": "host",
"operator": "=~",
"thresholds": [],
"timeFrom": null,
"timeRegions": [],
"timeShift": null,
"title": "Bitrate",
"tooltip": {
"shared": true,
"sort": 0,
"value_type": "individual"
"type": "graph",
"xaxis": {
"buckets": null,
"mode": "time",
"name": null,
"show": true,
"values": []
"yaxes": [
"format": "Kbits",
"label": null,
"logBase": 1,
"max": null,
"min": null,
"show": true
"format": "short",
"label": null,
"logBase": 1,
"max": null,
"min": null,
"show": true
"yaxis": {
"align": false,
"alignLevel": null
"aliasColors": {},
"bars": false,
"dashLength": 10,
"dashes": false,
"fill": 1,
"fillGradient": 0,
"gridPos": {
"h": 7,
"w": 8,
"x": 8,
"y": 4
"id": 19,
"interval": "",
"legend": {
"avg": true,
"current": true,
"max": true,
"min": true,
"show": true,
"total": false,
"values": true
"lines": true,
"linewidth": 1,
"options": {
"dataLinks": []
"pointradius": 2,
"points": false,
"renderer": "flot",
"alias": "packet_rate_download",
"spaceLength": 10,
"stack": false,
"targets": [
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"null"
"type": "fill"
"refId": "A",
"select": [
"params": [
"type": "field"
"params": [],
"type": "mean"
"tags": [
"key": "host",
"operator": "=~",
"alias": "packet_rate_upload",
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"null"
"type": "fill"
"refId": "B",
"select": [
"params": [
"type": "field"
"params": [],
"type": "mean"
"tags": [
"key": "host",
"operator": "=~",
"thresholds": [],
"timeFrom": null,
"timeRegions": [],
"timeShift": null,
"title": "Packet Rate",
"tooltip": {
"shared": true,
"sort": 0,
"type": "graph",
"xaxis": {
"buckets": null,
"mode": "time",
"name": null,
"show": true,
"values": []
"yaxes": [
"format": "pps",
"label": null,
"logBase": 1,
"max": null,
"min": null,
"show": true
"format": "short",
"label": null,
"logBase": 1,
"max": null,
"min": null,
"show": true
"yaxis": {
"align": false,
"alignLevel": null
"aliasColors": {},
"bars": false,
"dashLength": 10,
"dashes": false,
"fill": 1,
"fillGradient": 0,
"gridPos": {
"h": 7,
"w": 8,
"x": 16,
"y": 4
"id": 18,
"legend": {
"avg": true,
"current": true,
"max": true,
"min": true,
"show": true,
"total": false,
"values": true
"lines": true,
"linewidth": 1,
"options": {
"dataLinks": []
"pointradius": 2,
"points": false,
"renderer": "flot",
"alias": "loss_rate_download",
"spaceLength": 10,
"stack": false,
"targets": [
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"null"
"type": "fill"
"refId": "A",
"select": [
"params": [
"type": "field"
"params": [],
"type": "mean"
"tags": [
"key": "host",
"operator": "=~",
"alias": "loss_rate_upload",
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"null"
"type": "fill"
"refId": "B",
"select": [
"params": [
"loss_rate_upload"
"type": "field"
"params": [],
"type": "mean"
"tags": [
"key": "host",
"operator": "=~",
"thresholds": [],
"timeFrom": null,
"timeRegions": [],
"timeShift": null,
"title": "Loss Rate",
"tooltip": {
"shared": true,
"sort": 0,
"type": "graph",
"xaxis": {
"buckets": null,
"mode": "time",
"name": null,
"show": true,
"values": []
"yaxes": [
"format": "percent",
"label": null,
"logBase": 1,
"max": null,
"min": null,
"show": true
"format": "short",
"label": null,
"logBase": 1,
"max": null,
"min": null,
"show": true
"yaxis": {
"align": false,
"alignLevel": null
"aliasColors": {},
"bars": false,
"dashLength": 10,
"dashes": false,
"fill": 1,
"fillGradient": 0,
"gridPos": {
"h": 8,
"w": 12,
"x": 0,
"y": 11
"id": 9,
"legend": {
"avg": false,
"current": false,
"max": false,
"min": false,
"show": true,
"total": false,
"values": false
"lines": true,
"linewidth": 1,
"options": {
"dataLinks": []
"pointradius": 2,
"points": false,
"renderer": "flot",
"seriesOverrides": [],
"spaceLength": 10,
"stack": false,
"targets": [
"alias": "participants",
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"null"
"type": "fill"
"refId": "A",
"select": [
"params": [
"participants"
"type": "field"
"params": [],
"type": "mean"
"tags": [
"key": "host",
"operator": "=~",
"thresholds": [],
"timeFrom": null,
"timeRegions": [],
"timeShift": null,
"tooltip": {
"shared": true,
"sort": 0,
"type": "graph",
"xaxis": {
"buckets": null,
"mode": "time",
"name": null,
"show": true,
"values": []
"yaxes": [
"decimals": 0,
"format": "short",
"label": null,
"logBase": 1,
"max": null,
"min": null,
"show": true
"format": "short",
"label": null,
"logBase": 1,
"max": null,
"min": null,
"show": true
"yaxis": {
"align": false,
"alignLevel": null
"aliasColors": {},
"bars": false,
"dashLength": 10,
"dashes": false,
"fill": 1,
"fillGradient": 0,
"gridPos": {
"h": 8,
"w": 12,
"x": 12,
"y": 11
"id": 10,
"legend": {
"avg": true,
"current": true,
"max": true,
"min": true,
"show": true,
"total": false,
"values": true
"lines": true,
"linewidth": 1,
"options": {
"dataLinks": []
"pointradius": 2,
"points": false,
"renderer": "flot",
"spaceLength": 10,
"stack": false,
"targets": [
"alias": "total_memory",
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"null"
"type": "fill"
"refId": "A",
"select": [
"params": [
"total_memory"
"type": "field"
"params": [],
"type": "mean"
"tags": [
"key": "host",
"operator": "=~",
"alias": "used_memory",
"groupBy": [
"params": [
"$__interval"
"type": "time"
"params": [
"null"
"type": "fill"
"refId": "B",
"select": [
"params": [
"used_memory"
"type": "field"
"params": [],
"type": "mean"
"tags": [
"key": "host",
"operator": "=~",
"thresholds": [],
"timeFrom": null,
"timeRegions": [],
"timeShift": null,
"title": "Memory Usage",
"tooltip": {
"shared": true,
"sort": 0,
"type": "graph",
"xaxis": {
"buckets": null,
"mode": "time",
"name": null,
"show": true,
"values": []
"yaxes": [
"format": "decmbytes",
"label": null,
"logBase": 1,
"max": null,
"min": null,
"show": true
"format": "short",
"label": null,
"logBase": 1,
"max": null,
"min": null,
"show": true
"yaxis": {
"align": false,
"alignLevel": null
"refresh": "30s",
"schemaVersion": 22,
"style": "dark",
"tags": [
"jitsi"
"templating": {
"list": [
"allValue": null,
"current": {},
"definition": "show tag values from \"jitsi_stats\" with key=\"host\"",
"hide": 0,
"includeAll": false,
"label": null,
"multi": false,
"name": "jitsi_host",
"options": [],
"query": "show tag values from \"jitsi_stats\" with key=\"host\"",
"refresh": 1,
"regex": "",
"skipUrlSync": false,
"sort": 0,
"tagValuesQuery": "",
"tags": [],
"tagsQuery": "",
"type": "query",
"useTags": false
"time": {
"from": "now-6h",
"to": "now"
"timepicker": {
"refresh_intervals": [
"5s",
"10s",
"30s",
"1m",
"5m",
"15m",
"30m",
"1h",
"2h",
"1d"
"timezone": "",
"title": "Jitsi Meet",
"uid": "mcfIHGrZz",
"version": 44
}Code: Select all
[[inputs.http]]
name_override = "jitsi_stats"
urls = [
"http://localhost:8080/colibri/stats"
data_format = "json"
systemctl restart telegraf.serviceCode: Select all
apt install nftablesCode: Select all
#!/usr/sbin/nft -f
flush ruleset
table firewall {
chain incoming {
type filter hook input priority 0; policy drop;
iif lo accept comment "Accept any localhost traffic"
ct state invalid drop comment "Drop invalid connections"
ct state established,related accept comment "Accept traffic originated from us"
meta l4proto icmp icmp type { destination-unreachable, router-solicitation, router-advertisement, time-exceeded, parameter-problem } accept comment "Accept ICMP"
ip protocol igmp accept comment "Accept IGMP"
# established/related connections
# loopback interface
iifname lo accept
# icmp
icmp type echo-request accept
# open tcp ports: sshd (22), httpd (80)
tcp dport {22,80,443} accept # ssh und nginx
udp dport {10000} accept # videobridge
ip saddr 78.xx.xx.123 tcp dport {6556,4505,4506} accept # monitoring TIG Stack und CheckMK
table ip6 firewall {
chain incoming {
meta l4proto ipv6-icmp icmpv6 type { destination-unreachable, packet-too-big, time-exceeded, parameter-problem, mld-listener-query, mld-listener-report, mld-listener-reduction, nd-router-solicit, nd-router-advert, nd-neighbor-solicit, nd-neighbor-advert, ind-neighbor-solicit, ind-neighbor-advert, mld2-listener-report } accept comment "Accept ICMPv6"
# invalid connections
iifname lo accept
# icmp
# routers may also want: mld-listener-query, nd-router-solicit
icmpv6 type {echo-request,nd-neighbor-solicit} accept
ip6 saddr 2a01:xx:xx::123 tcp dport {6556,4505,4506} accept # monitoring TIG Stack und CheckMK
systemctl enable nftables;
systemctl start nftables;
systemctl status nftables --no-pagerCode: Select all
nft list ruleset
