Proxmox CLI
Proxmox CLI
Fassung vom 28.01.2019
Quelle: https://www.thomas-krenn.com/de/wiki/Pe ... ter_Debian
Hinweis: Wer nur die Community Version, nicht aber die Enterprise Version von Proxmox nutzt, sollte die pve-enterprise.list löschen.
rm /etc/apt/sources.list.d/pve-enterprise.list
apt update
Bei Problemen mit den locale settings unter der Verwendung von pveum ...
apt-get install multipath-tools
localedef -i de_DE -f UTF-8 de_DE.UTF-8
dpkg-reconfigure locales
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LC_CTYPE = "de_DE.UTF-8",
LANG = "en_US.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
locale: Cannot set LC_MESSAGES to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
/usr/bin/locale: Cannot set LC_MESSAGES to default locale: No such file or directory
/usr/bin/locale: Cannot set LC_ALL to default locale: No such file or directory
Generating locales (this might take a while)...
de_DE.UTF-8... done
en_US.UTF-8... done
Generation complete
Link: https://pve.proxmox.com/wiki/User_Management
Top
