Docker Grundinstallation Debian/Ubuntu
Serververwaltung mit Salt Stack, Logging und Monitoring mit ELK-Stack und TIG-Stack
aktualisierte Fassung vom 21.12.2018
Quelle: https://docs.docker.com/install/linux/d ... repository
Für Debian:
apt install apt-transport-https ca-certificates curl gnupg2 software-properties-common
curl -fsSL https://download.docker.com/linux/debian/gpg | sudo apt-key add -
apt-key fingerprint 0EBFCD88
add-apt-repository "deb [arch=amd64] https://download.docker.com/linux/debian $(lsb_release -cs) stable"
apt update && apt install docker-ce
Bezugsquelle für fertige Docker Container: https://hub.docker.com/
Docker Container über Dockerhub beziehen
docker pull $dockercontainer$
Beispiel
docker pull nginx
Docker Installation testen
docker run hello-world
# docker run hello-world
Unable to find image 'hello-world:latest' locally
latest: Pulling from library/hello-world
d1***2****c****0*: Pull complete
Digest: sha256:**************d*************6****************7*************
Status: Downloaded newer image for hello-world:latest
Hello from Docker!
This message shows that your installation appears to be working correctly.
To generate this message, Docker took the following steps:
1. The Docker client contacted the Docker daemon.
2. The Docker daemon pulled the "hello-world" image from the Docker Hub.
(amd64)
3. The Docker daemon created a new container from that image which runs the
executable that produces the output you are currently reading.
4. The Docker daemon streamed that output to the Docker client, which sent it
to your terminal.
To try something more ambitious, you can run an Ubuntu container with:
$ docker run -it ubuntu bash
Share images, automate workflows, and more with a free Docker ID:
For more examples and ideas, visit:
https://docs.docker.com/get-started/
Docker Prozesse anzeigen lassen
docker ps -a
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
*****e*******8******** hello-world "/hello" 18 seconds ago Exited (0) 16 seconds ago heuristic_mccarthy
**a******4******1***** nginx "-d -p 80" 3 minutes ago Created 80/tcp upbeat_banzai
***c*****1****5******* nginx "nginx -g 'daemon of…" 4 minutes ago Exited (0) 4 minutes ago happy_elgamal
Docker Container starten
Quelle: https://www.digitalocean.com/community/ ... untu-14-04
sudo docker run --name docker-nginx -p 80:80 -d nginx
Docker Container stopen
docker stop docker-nginx && docker rm docker-nginx
Docker Kommando Übersicht unter https://docs.docker.com/engine/reference/commandline/
